Rostock Max
Posted: Sun Mar 24, 2013 1:25 pm
Her are some pictures from my Rostock Max.
I made a complete housing for it with a few changes on the printer itself.
[img]https://lh6.googleusercontent.com/-z-E2 ... 122257.jpg[/img]
The housing consists of heat-and acid-resistant plastic discs 5 mm thick with 20x20mm aluminium profiles.
The bottom is composed of 19mm thick solid wood.
The housing helps alot for minimize the noice and keep the temperature warmer inside (+4°~).
[img]https://lh3.googleusercontent.com/-4KFK ... 122332.jpg[/img]
Here on the hotend i changed the aluminium spacers, made them much shorter so i have more space later for a cooling fan.
Difficult here foreseeable my custom 0.30 mm noozel, i changed the shape and length (2mm longer). From thingiverse i also printed the 3x LED holder you that you can see.
[img]https://lh5.googleusercontent.com/-pm7A ... 122401.jpg[/img]
On the top 3 more LEDs.
[img]https://lh5.googleusercontent.com/-G06r ... 102820.jpg[/img]
For Steves Extruder i made 1 LED holder so i can see when the filament gets stuck again...
[img]https://lh5.googleusercontent.com/-8Lt1 ... 122345.jpg[/img]
No more pocket lamp ^^
For everything i made some switches.
[img]https://lh6.googleusercontent.com/-NjSf ... 131636.jpg[/img]
1 for power, 1 for the 3 hotend LEDs and 1 for the 3 top LEDS and the 1 @ the extruder.
Rostock Max in the dark.
[img]https://lh3.googleusercontent.com/-F5Wf ... 181325.jpg[/img]
The material costs are at 250€ when you buy it from the internet, but i only payed around 120€for it (got everything from my company)
Sorry for my bad english btw <.<..
