Big thanks to all that were involved in putting on that event!
Got 4 test prints done without getting into serious calibration - she works well!
I do have a script that can be pasted into the GCode editor "Script xx" and saved that will make sending commands to get the end stops dialled in a little easier
; This is written for a Rostock Max with an Onyx bed - if you have the smaller square beds the
; extruder head will be off the side of your bed!
; Make sure you have your Z0 set and stepper directions set correctly otherwise
; you might crash the extruder into the bed or the sliders into the ceiling
g28 ; Home all axes
g01 x0 y0 z20 f7500 ; Drop to centre of bed (~20mm off)
g01 f500 ; Slow moves
; ****!!! DANGER make sure this won't crash the extruder DANGER !!!***
; I suggest starting with Z10 and eyeballing it the first time, then reducing the value.
g01 x0 y0 z1 ; Drop closer to bed (~1mm)
m1 s10 ; Pause ten seconds
g01 x-103.92 y-60 ; Go towards X pillar
g01 x0 y0 ; Centre carriage
m1 s3 ; Pause three seconds
g01 x103.92 y-60 ; Go towards Y pillar
g01 x0 y120 ; Go towards Z pillar
g01 x0 y0 z20 f7500 ; Raise carriage for adjustment of end stops
m1 s20 ; Pause twenty seconds
m84 ; Stop idle hold (Releases steppers)
I found fixes here...
Create rules that automatically rename USB serial adapter to the same thing.
https://gist.github.com/cbrake/4337154
Automattically reset permissions each time the device is created (Plugged in)
http://www.libelle-systems.com/free/win ... ccess.html
