Rambo pre-programmed
Posted: Tue Apr 02, 2013 12:39 am
by leafi
Hey everyone
On the seemecnc assembly video they say that the rambo will be preprogrammed and the esd bag will be open when we receive the board. The board I received, the esd bag was still sealed. Does this mean I need to program it or are they re-sealing the ESD bags?
Thanks
Re: Rambo pre-programmed
Posted: Tue Apr 02, 2013 2:20 am
leafi wrote:Hey everyone
Thanks
Doesn't matter either way you have to change the firmware and reprogram it even if it's just to set the correct Z height.
Posted: Tue Apr 02, 2013 1:02 pm
by cassetti
Pretty sure the RAMBo 1.1 boards shipping with the Rostock Max are pre-loaded with marlin firmware configured for standard cartesian printers, this is NOT compatible with delta printers.
Also the Marlin firmware provided by SeeMeCNC (Johny99's) doesn't provide support for the LCD screen (If i'm not mistaken). The firmware by Polygonhell does.
Posted: Tue Apr 02, 2013 5:36 pm
by Darth
cassetti wrote:Pretty sure the RAMBo 1.1 boards shipping with the Rostock Max are pre-loaded with marlin firmware configured for standard cartesian printers, this is NOT compatible with delta printers.
So where do we download the Polygonhell firmware?
Posted: Tue Apr 02, 2013 5:37 pm
by cambo3d
Darth wrote:cassetti wrote:Pretty sure the RAMBo 1.1 boards shipping with the Rostock Max are pre-loaded with marlin firmware configured for standard cartesian printers, this is NOT compatible with delta printers.
marlin does work as long as you set it up properly here is repetier firmware link
https://github.com/polygonhell/Repetier-Firmware
Posted: Wed Apr 03, 2013 4:57 pm
by Darth
cambo3d wrote:Darth wrote:cassetti wrote:Pretty sure the RAMBo 1.1 boards shipping with the Rostock Max are pre-loaded with marlin firmware configured for standard cartesian printers, this is NOT compatible with delta printers.
O.K. for a newbe, just getting ready to install the software for my Rostock MAX, should I install the Marlin per the manual, (set it up right??????) or download the Polygonhell and install it? This is all starting to confuse me. I figure following the manual step by step hopefully will get me running.
Posted: Wed Apr 03, 2013 5:10 pm
by cambo3d
"O.K. for a newbe, just getting ready to install the software for my Rostock MAX, should I install the Marlin per the manual, (set it up right??????) or download the Polygonhell and install it? This is all starting to confuse me. I figure following the manual step by step hopefully will get me running.[/quote]"
repetier firmware is a lot easier to install and get up and running.
marlin requires you to mess with the firmware code if you want to get your lcd working.
your choice really. how comfortable do you feel about looking at lines of code.
Posted: Thu Apr 04, 2013 9:54 am
by cassetti
I personally skipped the Marlin firmware all together, and uploaded the polygonhell firmware to my Rambo. Haven't had any complaints
