Dual Hotends
Posted: Tue Apr 02, 2013 8:27 pm
I am really interested in Dual hotends, I know some other more conventional printers are doing this both in forms of Mods to exsiting machines and units that are coming preassembled with dual hotends.
I think the multi color idea is cool, but I am way more into multi materials. Really interested in Water Soluble materials like the MakerBot PVA etc. I would really use this material for supports while printing more complex parts with overhangs etc. I think that printing with supports would give you a much cleaner print than when the printers currently overthrow or spit out more of the normal material and get it to hang etc.
So with the Delta platform, what would be needed to support a Dual head? It seems like the RAMBo can support it as it has 5 stepper controllers, an extra one for the 2nd extruder right? Can it take controlling another hot end with the temp etc?
Would you just need to make a wider main platform to fit both heads and then the configuring part with software?
I am an 100% newbie with printers so if someone who has thought about this could shed a little light that would be fantastic.
Edit.
After thinking for a moment, I realized that while I think two heads would be enough right now and that Im not really into mutli color.... Im sure that would change down the road after I have built and used a 3D printer for a while. If we could add a "hot end bank" with 3 to xx number of hot ends that the Delta form printer could navigate to and lock on and then use to print, then put it back and grab the next one required.... All the while knowing when to bring each one to temp etc.
That would be epic. Ok the Idea is there. Now how do I turn that into a reality!
Edit.
