gap between rails and top plate?
sandy
Post by sandy »
Hi,
I'm having real trouble with the rails and the top plate alignment. No matter what I try I can't get rid of a 1-2mm gap. My rails are loose and I can move them so it isn't that.
I've tried pressing a rail hard against the top, while I tighten the screws, but the instant the screws are even moderately tight the gap is back. Is there anything else I can try?
thanks,
-sandy
cambo3d
Re: gap between rails and top plate?
Post by cambo3d »
this is not an accurate way to align your extrusion but I everytime I happen to say something about the way the manual is. I get called a whiner.
sandy, you will need to measure the distances in order to get your towers aligned better.
sandy
Post by sandy »
Will do. I've just watched that bit in the vid.
thanks,
-sandy
