How to control heat to hotend seperately from Rambo.
Posted: Fri Apr 05, 2013 8:43 pm
by Flateric
I would like to make some use of my 2nd rambo that has failed thermistor inputs.
I am certain I can disable the checks repetier makes allowing it to continue along unaffected. I think it should be possible anyways, experts? Polygonhell?
How can I control the hotend temp independantly from my Rambo? Essentially a seperate and independant subsystem that is incharge of my hotend and even better the heated bed as well?
This must be possible....
Re: How to control heat to hotend seperately from Rambo.
Posted: Fri Apr 05, 2013 8:47 pm
by cambo3d
use a standalone pid controller and matching sensor for it. ill find a link for one. but these are commonly sold via ebay example: http://www.ebay.com/itm/AC-110-240V-Dig ... 20cfb9bd52 i dont know if the thermistors from the rambo kit are compatible, something you would have to test out.
Posted: Fri Apr 05, 2013 9:00 pm
by Flateric
Thanks for the quick response!
My only concern would be if it can output to our ceramic cartridge heater? And if not, does it have a solution small enough for the carraige of a delta?
Not a bad solution though, very nicely packaged and the digital readout would be wonderful for both the heated bed and the hotend.
Price is right too!
Posted: Fri Apr 05, 2013 9:07 pm
We did that from the get-go with the original H-1 printers! Use a Velleman temp controller. They are cheap ($9 each) and quick to assemble. There is lots of info on this forum. You do need to mod a resistor for the hot end to get into the temp range and similarly for the heated bed. This is a lot cheaper than a PID and works just fine for either hot end or heated bed. It can power the cartridge heaters too, no problem there.
Posted: Fri Apr 05, 2013 9:11 pm
by Flateric
Hey....I have one of these already somewhere here.
Can you point me in the direction for the thermistor mod hookup?
Thankyou as always guys, so helpful.
Posted: Fri Apr 05, 2013 9:17 pm
It's documented in my H-1 electronics manual
