Easier way to sand the Rostock arms
Posted: Sat Apr 06, 2013 4:22 pm
I have found that if I stack seven emery boards they are almost perfect width to sand the Rostock arms.
After stacking the seven and squeezing them between the ends of the arms then sand and sand and sand the
final result is an arm with a virtually perfect space to fit the joints without slop. The emery boards I used were
from Walmart, Company name Trim in a pack of 20. 00348 is a part number in the top right of the package.
Carl
Re: Easier way to sand the Rostock arms
Posted: Sat Apr 06, 2013 5:33 pm
by cambo3d
I been trying to find a better way to do this also. I was thinking along the same lines.
Posted: Sat Apr 06, 2013 6:58 pm
by foshon
Eaglezsoar wrote:I have found that if I stack seven emery boards they are almost perfect width to sand the Rostock arms.
Carl
Carl I do believe I love you!!
Thanks
Posted: Sat Apr 06, 2013 7:42 pm
foshon wrote:Eaglezsoar wrote:I have found that if I stack seven emery boards they are almost perfect width to sand the Rostock arms.
Carl
Thanks
Let's take it easy, this is a public board.
Posted: Sun Apr 07, 2013 3:09 pm
by foshon
Eaglezsoar wrote:foshon wrote:Eaglezsoar wrote:I have found that if I stack seven emery boards they are almost perfect width to sand the Rostock arms.
Carl
Thanks
Like a brother man, like a brother.
Posted: Sun Apr 07, 2013 4:09 pm
Brother it be, brother. Tell Mom I said Hey!
Carl
Posted: Sun Apr 07, 2013 4:49 pm
by foshon
Eaglezsoar wrote:Brother it be, brother. Tell Mom I said Hey!
Carl
Will do, pot roast tonight, you in?
Posted: Tue Jun 25, 2013 4:00 am
by krak
That tip is worth a few minutes of searching and a couple of dollars at wally world. Thank you.
Posted: Tue Jun 25, 2013 8:47 am
foshon wrote:Eaglezsoar wrote:Brother it be, brother. Tell Mom I said Hey!
Carl
MOM!!!!!! Meatloaf!!!!!!!
What does she even do in there?
Posted: Tue Jun 25, 2013 9:13 am
Mom makes Pot Roast and Meatloaf.
She also takes care of Foshon who creates 3d printed Pot Roast and Meatloaf servers.
Posted: Tue Jun 25, 2013 11:00 am
by doctorgonzo
You guys are goofy. It's great.
Posted: Tue Jun 25, 2013 11:15 am
What's great, the Pot Roast, the Meat Loaf or the sanding idea?
Posted: Tue Jun 25, 2013 2:37 pm
by doctorgonzo
All of the above ^^^
Posted: Tue Jun 25, 2013 3:49 pm
by lordbinky
Sanding meat loaf with a pot roast sounds delicious.
edit: I can't be the only one who read it that way...
Eaglezsoar wrote:What's great, the Pot Roast, the Meat Loaf or the sanding idea?
Posted: Tue Jun 25, 2013 6:12 pm
by foshon
lordbinky wrote:Sanding meat loaf with a pot roast sounds delicious.
What grit do you recommend, and wet or dry?
Posted: Tue Jun 25, 2013 7:38 pm
by lordbinky
foshon wrote:lordbinky wrote:Sanding meat loaf with a pot roast sounds delicious.
This requires testing and datasheets. My intuition is that because meatloaf needs ketchup, wet. I think you have to add the grits to the meatloaf though.
Posted: Tue Jun 25, 2013 7:43 pm
by foshon
lordbinky wrote:foshon wrote:lordbinky wrote:Sanding meat loaf with a pot roast sounds delicious.
Sounds tasty Chef lordbinky! As well as smooth!
Posted: Tue Jun 25, 2013 9:03 pm
You guys are all nuts!
Posted: Wed Jun 26, 2013 12:30 pm
by doctorgonzo
This is true, and this thread has been seriously derailed in the best possible way
Posted: Wed Jun 26, 2013 1:13 pm
And to think I helped to derail my own thread!
