Batteau62's Black w/ white edges MAX build
Posted: Fri Apr 12, 2013 11:55 pm
by Batteau62
Ok, I finally found some time to post some photos of the beginning of my build. So here we go...
I have already built a Printrbot jr. That kit has been pretty successful. I have had some good prints and some failures. I only use PLA on it (no heated bed)
I do like the portability of it. It's very small! Enough Printrbot, onto Rostock MAX!
- Received the box in good shape.
No external damage, always a good thing.
- Nice packing!
Who doesn't love packing peanuts? Thank the powers for a good shop vac.
- Taking inventory
- Lots of parts
It all seems to be here. I didn't count every small piece, nut and bolt.
After inventory it was time to paint the edges. My daughter suggested white, so white it is.
- Thanks for the pre-mask on the parts!
I read a lot of complaints on removing the masking on the forum. I would like to thank SeeMeCNC for giving me already masked and ready to edge paint parts.
- Edge painting on a nice day.
- Parts unmasked and ready.
A trick I learned from working in the sign industry- Use a hair dryer or heat gun to heat up masking tape and paper before/during trying to peel it. I peeled almost complete pieces off of the large bottom and top circles.
- The base construction.
Having done my share of eletro-mechanical assembly, I think this part of the build I can handle. I will have some ?'s on electronics though. I'm still learning there.
- Basic structure complete.
Basic struture done. Moving onto the bearing surfaces of the delta arms etc. My weapon of choice is this little warding file handed down from my dad.
I seemed to have reached the attachment limit here, so this is a link to my facebook album of my build.
https://www.facebook.com/media/set/?set ... fa0c13d6a3
The pic with the dual spool holders and the delta arms looks very sculptural to me. I like it! I hope I can get the dual extruders working, I'm approaching the build with that as the goal.
The last pic is the beginnings of my "cheapskates". Everything seems to be going ok with them, although I could use three hands for the adjustment!
More to come...
Re: Batteau62's Black w/ white edges MAX build
Posted: Sat Apr 13, 2013 7:50 am
by cassetti
Wow! Looking real good so far!
Welcome to the boards, you'd be amazed how fast people get back to you on questions. It's REALLY helpful. I built a prusa mendel i2 from a candian vendor - their forum is a ghost town, and customer service took about 4-5 days to respond to questions. It was refreshing to see the level service I've received from both SeeMeCNC and this forum.
Posted: Sat Jun 08, 2013 1:22 pm
by Batteau62
So, I've been stretching this build since April. This morning I finally applied power...and...all is well! Pics are in a facebook album(link is in earlier post for those interested). Of course as I was waiting for a file to load, I had to play with the hotend...and...pulled out the thermistor! @#$%! ensued... a screw in replacement is on order.
Next on the agenda is system testing/calibration(when thermistor sets up! grumble...grumble). I am also looking at some mods-mag arms, new hotend, lights, probably more...dual extruders! Yeah!
Anyway, much thanks to everyone on this forum. It's been a real pleasure reading the sage wisdom from so many sources. And I hope to continue with it for some time.
Posted: Sat Jun 08, 2013 2:16 pm
Do you have the dual extruders working and if so would you be willing to post how and what you did to get them
working along with the settings in Repetier, your slicer, etc. We are anxiously waiting for a dual extruder completion.
Posted: Sat Jun 08, 2013 2:27 pm
by Batteau62
No, no dual exruders yet. That one is definitely high on my list. I think it is for lots of us. I noticed this on amazon today. Interesting, but I want to keep the bowden setup and minimal effector weight for speed.
http://www.amazon.com/0-4mm-Nozzle-Extr ... 3d+printer
Posted: Sat Jun 08, 2013 2:49 pm
Batteau62 wrote:No, no dual exruders yet. That one is definitely high on my list. I think it is for lots of us. I noticed this on amazon today. Interesting, but I want to keep the bowden setup and minimal effector weight for speed.
Very nice, it could be what is needed. It does use Type K thermocouples instead of thermistors so that would need some conversions either hardware or firmware.
It also appears to use the QU-BD type of filament pusher where the filament passes past a gear and a setscrew. The QU-BD design never worked very well and I'm
afraid that the one on Amazon won't work very well either. The two adjustable "thingies" on the sides is the giveaway that tells me that it is using the QU-BD design.
Posted: Sun Jun 09, 2013 2:08 am
by kbob
I am responding late, but I really like your color scheme.
How did you do the white lettering? Did you use the laser-cut tape as a mask?
Posted: Sun Jun 09, 2013 7:07 am
by Batteau62
That's exactly what i did. The guys at SeeMe were nice enough to include the already masked parts, so I figured a nice edge paint was in order.
Posted: Sun Jun 09, 2013 3:25 pm
by kbob
Batteau62 wrote:That's exactly what i did. The guys at SeeMe were nice enough to include the already masked parts, so I figured a nice edge paint was in order.
I was afraid that was your secret. My masking tape is long gone, so I won't be doing that (unless I order another one for some reason).
Posted: Mon Jun 10, 2013 8:47 pm
by Batteau62
Had some interesting things happen with calibration:
-I switched my stepper pins to get the movement direction correct. That worked fine.
-I wanted the lcd/Rambo to be powered by the psu, so I moved the jumper pin. That caused an issue. My lcd stopped working? I was back to white boxes? I puzzled over it for hours and I was about to change some config settings. Then I noticed the "TX and RX" lights flashing yellow on the Rambo? Not sure, do these mean-transmission and reception? Anyway, I was looking at them and noticed my lcd adapter looked unplugged a little. It was. When I opened the electronics bay door. I must have strained the lcd cables enough to loosen the adapter. My fix uses a trick I learned in the sign industry. Use a roll pin as a stop. Fortunately the holes in the top of the MAX are perfect for 1/8th" pins. I have one in the hole over the "e" in "ROSTOCK MAX SeeMeCNC.com" logo. It keeps the door from closing the whole way, that keeps it from interfering with my mod of the heater bed caution light mounted there. The other is to the left of the "R" in the logo. It keeps the door from opening the whole way. I'll remove it if I need to do maintenance in the bay. Lesson learned-Always check your connections!
I'm getting ready for my first print, hopefully tomorrow. I'm sure I will be posting my progress, good or bad:)
Posted: Tue Jun 11, 2013 12:05 am
by Flateric
I did nearly the same thing, but black with silver edges and silver text. Still nice color choice!
I approve.
LOL
Posted: Tue Jun 11, 2013 9:20 pm
by Batteau62
Ok, here is my "giddy schoolgirl" video. First power...no sparks...good...then G28...up to the limits...Yes! The Black & White Max shows signs of life
https://www.facebook.com/photo.php?v=35 ... 7094819088
Posted: Wed Jun 12, 2013 9:21 am
\o/
Posted: Wed Jun 12, 2013 10:08 pm
by Batteau62
First print:
https://www.facebook.com/photo.php?fbid ... c5645bbb6a
https://www.facebook.com/photo.php?fbid ... 0b6334242e
https://www.facebook.com/photo.php?fbid ... e0d23e1219
I had some issues on the first try. I think they were comm related, more testing required. I did video which is too long to post. I will trim it and post it, because there are some noises during the print that don't seem normal. They were like a judder or jerk in the arms and effector. Might be mechanical? Over all I'm very optimistic with the results
As always comments and feedback would be much appreciated.
Posted: Thu Jun 13, 2013 4:58 am
I think that looks really good for a first print. Good job in getting to this point.
Now it is a matter of tweaking and tweaking.
Posted: Thu Jun 13, 2013 6:08 pm
by Batteau62
I think my calibration pyramid would have done better with a bed fan. So this is my addition:
- locline fan
I also placed a second psu in the storage bay. Sort of temporary, I may remove the door and re-orient it. Velcro is a woderful thing! I'm running the bed fan off it, and the plan is to add lighting.
Posted: Thu Jun 13, 2013 9:51 pm
by Batteau62
Posted: Tue Jun 18, 2013 3:22 pm
by Batteau62
Some recent printing. I think I'm getting things dialed in. Some prints throw curve balls, but the problem solving is what makes it fun
This is my facebook album, the latest parts are mostly xnaron's mag arm mod parts. I was using these as calibration prints, so I think I could get better results now.
I did print a 20mm calibration cube. I thought it looked pretty good. It was a little small, but well within my tolerance limits.
Happy printing!
As usual, observations welcome...
Posted: Thu Jun 20, 2013 10:58 pm
by Batteau62
First print video, I actually did this last week. I had to chop it down from the original 2GB version. I have since been working on calibrating and mods. I printed my first "in service" part today, a simple clip for a sliding seat in my rowing scull. So cool to be able to make a part you need on the spot!
https://www.facebook.com/photo.php?v=35 ... 5130259985
Posted: Fri Jul 26, 2013 12:24 pm
by Batteau62
Added dampers to my steppers this am, Wow!, really does make the Max much quieter. I also added a 40mm fan next to the Rambo that blows continuously from the center out. My original mount of the board used 1" standoffs. I'm glad I did it. I think it left a lot of cooling space behind the board. I think the addition of the fan can only help.
Next mod(after some printing
) will be mounting my new e3d hot end
, building it now, can't wait to get that one going. I also have plans for the xnaron mag arms and some extrusion/pillar mods. (This last one may turn into a 2nd custom Max
Posted: Fri Jul 26, 2013 2:32 pm
Batteau62, I meant to ask you this before but I forgot, is that fan on the end of the flexible arm a Thingiverse item?
Posted: Fri Jul 26, 2013 4:53 pm
by Batteau62
No, but this is the same thing.
http://www.thingiverse.com/thing:9457 And if you search "loc line" on Thingiverse you should find more. The fan is out of an old psu. The connecting piece from the line to the fan is custom by me. It's just a piece of pvc pipe machined to fit the corner of the fan. I love this stuff, it's great for a wire run, bends in any shape you need and protects the wire. I have a smaller version on my "third hand" for soldering. Attach an alligator clip, bolt it to your stand and you have an unlimited amount of motion.
Posted: Wed Nov 06, 2013 3:59 pm
by Batteau62
Well haven't posted here in a while
I just did a couple of upgrades to my max. Installed Trick Laser "add a inch" carriages and CF arms. Really nice products
Highly recommended
Couple of hiccups on first prints after recalibrating. I thought they might be worth mentioning.
I printed the 20mm cube first, it was leaning badly
After I read through the forum posts, my instincts said mechanical-too much friction somewhere. So my first try was to loosen my belts(instead of raising stepper current). The result was less lean
but still not acceptable, so next I re-tweaked the cheapskates. And that seems to have done the trick. So important to get the movement of this machine to be no lash with no friction
Next, I printed the hollow pyramid and it looks well formed
I will be more confident when I print more objects.
I started down this road when my stock arms started making terrible noises. Like bad binding was happening. And sure enough when I tore them down, two of the aluminum universal joints were near frozen on the axles? I think something "foreign" built up on them, dust or who knows? If you have them, keep them clean.
I did the "add a inch" carriages in preparation for experimenting with mechanical bed leveling:
http://forum.seemecnc.com/viewtopic.php ... 173#p21173 and a possible frame upgrade, more on that later
Happy printing
