DELTA RADIUS?
Posted: Tue Apr 16, 2013 10:19 am
by cassetti
Guys,
I've seen several people mention calibrating the delta radius. I've never done this step. Any links to the post? Again, the search feature on this forum stinks, couldn't find any relevant results
Re: DELTA RADIUS?
Posted: Tue Apr 16, 2013 11:41 am
I use Google to search the forums because the search function here is so bad. In Google search put in site:forum.seemecnc.com (what you are searching for)
If I use the Forum search to find "repetier" it won't search so I go to Google and type in site:forum.seemecnc.com repetier and it finds a lot of entries.
Re: DELTA RADIUS?
Posted: Tue Apr 16, 2013 11:45 am
This is the closest thing to a guide on the forum
http://forum.seemecnc.com/viewtopic.php ... 74&start=0
This is the guide I used to recommend
http://minow.blogspot.com/
Re: DELTA RADIUS?
Posted: Sat Apr 20, 2013 10:47 am
by cassetti
Polygonhell wrote:This is the closest thing to a guide on the forum
I followed the minow blog, and found that I had a 0.20mm hump in the middle (M114 reports 0.19 for Z, so fine, 0.19). But when I look up the configuration.h for delta radius I find this:
#define DELTA_RADIUS (PRINTER_RADIUS-END_EFFECTOR_HORIZONTAL_OFFSET-CARRIAGE_HORIZONTAL_OFFSET+0.0)
Do I set the offset to +0.20?
Re: DELTA RADIUS?
Posted: Sat Apr 20, 2013 11:45 am
I just stuck .5 where it reads +0.0.
Remeasured, if it as worse in the same direction I wend to -0.5
Then I just adjusted the number iteratively, after 3 or 4 guesses it was pretty close.
Be careful not to hit the table when you're making changes
