Should I get the new pulleys?
Posted: Wed Apr 24, 2013 12:44 am
Are the new pulleys worth the upgrade? do they give better control? Or are they just for stripped belt issues?
Bill
Bill
Have a look around and join today!
https://download.seemecnc.com/
They're probably just cheaper, you can't buy 15 tooth plastic pulleys, at that size they have to be all metal, which increases the price.bplemmons wrote:Are the new pulleys worth the upgrade? do they give better control? Or are they just for stripped belt issues?
Bill
Now I have a migraine, I need some Excedrin after reading that.Jimustanguitar wrote:That's an interesting point about print resolution...
20 step motors
16th step electronics
Means 320 clicks per rotation...
Using a 2mm toothed belt, the circumference of the 15 tooth gear is 30mm and the 20 tooth is 40mm...
Sooo..... a 15 tooth pulley can accurately position a carriage to .09375mm and a 20 tooth gear to .125mm.
Does this .03125mm matter when you're printing .2mm layers? Could you even detect a difference in the print? Keep in mind that all 3 carriages are moving at the same time to triangulate any given move... My head hurts
Holy crap, you're right! Add a decimal place to all of my math.... Um, I mean...... Stupid autocorrect changed all of my µm's into mm'sdbarrans wrote:20 steps per rotation? Are you sure that's not 200?
- dan
