what is happening with my prints?
Posted: Thu Apr 25, 2013 4:00 pm
by bplemmons
The top layer of all of my prints look like this, I have tried 5 horizontal shells and it looks like it is only printing one thin one.
my extruder multiplier is set to .9 and the cube is 24.8 x 24.8....
Re: what is happening with my prints?
Posted: Thu Apr 25, 2013 10:43 pm
by Flateric
This very strongly looks like filamnent starvation to me. Your infill also looks a bit starved too. Try setting that .9 multi higher.
If you crank the speed of extrusion up to 300% at the end when it is doing the top does it help at all? Note, I do not mean the speed of print, but the speed of filament extruded.
Get back to use with your results.
One last thing, if you are using slicer, do not let it autoselect your extrusion width. Set it manually to the size of your nozzle for a starting point go from there.
Posted: Thu Apr 25, 2013 11:27 pm
by bplemmons
How do you change the extruder width? in g code?
Bill
Posted: Thu Apr 25, 2013 11:54 pm
by Flateric
Are you using slic3r from within Repetier host?
Posted: Fri Apr 26, 2013 2:32 am
by bplemmons
I have tried kiss as well, I did put the nozzle guide from here in the extruder and it is printing much better. Will post some pics soon...
Bill
Posted: Fri Apr 26, 2013 3:28 am
by Flateric
It also occured to me that perhaps you have not got your extruder steps per mm setup correctly in the firmware, maybe?
Posted: Fri Apr 26, 2013 4:35 pm
by bplemmons
I have it set to 584, I have the rambo 1.1 (16 steps right?)
Posted: Fri Apr 26, 2013 4:51 pm
by Flateric
Yes, that is the setting I was referring to. Ok, good. So have you made progress, how is it going now?
Posted: Fri Apr 26, 2013 11:24 pm
by bplemmons
Here is the latest, a lot of it was not having the temp high enough, I'm running 190-200 now...
I am still getting some stringing on the columns but I have retraction set at 10, going to try 11....
Bill
Posted: Sat Apr 27, 2013 12:25 am
by Flateric
ABS or PLA? IF your running ABS I would say that this is even still too low a temp.
As far as retract goes this is heavily influenced by each and every build. Hard to recommend there, but I run my retraction at 5-6, with a 1mm lift. I also find that the speed of the retraction can be too fast (or too slow) and have more of an effect then the length of the retraction. Also as you go hotter you make the filament softer and then this can affect how effective speed and retraction amount work effectively. Eventually you'll settle into a butter zone though.
Posted: Sat Apr 27, 2013 2:28 am
by bplemmons
Sorry, its pla, I must say, I am running Cura now, It's like a different machine!
I will post a video tomorrow in a new thread....
Bill
