Slic3r Retract On Layer Change giving Negative G-Code Value
Posted: Sun Apr 28, 2013 12:14 pm
Why is it when you check "Retract on Layer Change" in Slic3r, you get a negative G-code value upon entering the second layer? It digs right into the build platform. I could not figure this out, 'till I unchecked "Retract on Layer Change" and noticed the resulting G-Code no longer spat out a negative value.
