Oh OH left printer on too long! Bed problem
Posted: Fri May 03, 2013 12:20 am
Hey folks
Have a problem
Was warming up my Rostock for a print, then a friend came over....3 hours later I remembered I had it on!
Now the left side of the bed ( I have the original Square bed ) is LOWER than the rest from roughly the top ( Z tower ) to the bottom of the X & Y towers.
At least that's how it seems although visually it looks perfectly straight.
When I bring the nozzle to 0mm off the bed and use G1 X70 and G1 X-70 commands, from the Center to the right it's fairly level But from Center to the Left X tower the Nozzle slowly moves higher off the bed.
I tried putting a washer in the 3 screws of the bed to raise that side slightly but didn't do alot maybe a bit but not enough.
It's a mm or 2 higher enough to not allow large print test to stick properly on that side.
Also on this topic is there a CUT OFF TIME that can be put in the code if the heat is on to turn off if no activity say after 10 minutes?
That would have saved me this problem...it might even be there for all I know unset.
Any idea's on how to go about getting the bed flat now?
thanks
Have a problem
thanks
