Backing up firmware
Posted: Fri May 03, 2013 8:38 pm
If I am using a copy of repetier and have it configured the way I want it, is there anyway to create a backup of the firmware
so that I have a copy in case of catastrophic failure. I read about AVRDUDE but I'm not sure if that is what I want to create
such a backup. Is there anyone who can help with this?
Re: Backing up firmware
Posted: Sat May 04, 2013 9:26 am
If you've configured it the way you want it, you've ALREADY got a backup - the source code! Burn it to a CD or throw it on a thumb drive.
Posted: Sat May 04, 2013 10:25 am
Isn't it amazing how I can take the simplest of things and make them difficult.
You are 100 percent correct. Now I wonder why such utilities such as AVRDUDE and
AVRDUDEGUI exist. This is such a complicated hobby, I should have tried something
simpler like being a brain surgeon. :)
Posted: Sat May 04, 2013 11:21 pm
by cjdavis618
Eagle, I'm the same way.
Being in the IT field, EVERYTHING needs a backup before you work with it. So I figured the Arduino did also in order to make changes. . Your weren't alone.. :-)
Posted: Sun May 05, 2013 1:32 am
by ApacheXMD
Sure you've got a copy of the source code, and but you've probably changed a bunch of things in eeprom. How can we backup those settings?
If you change settings in eeprom and don't like it, is there an easy way to revert back to a known good configuration?
If you just compile and upload an old firmware version, but your eeprom settings from last time will still remain.
Posted: Mon May 06, 2013 9:49 am
I don't know of a built-in facility for backing up the EEPROM settings, but doing a screenshot of the EEPROM settings window and printing it would work pretty well. (or save the image to your backup media!)
Posted: Mon May 06, 2013 10:36 am
by dbarrans
Might look into using RCS or some other revision tracker to track changes to the source code.
- dan
Posted: Mon May 06, 2013 11:45 am
*cough* github *cough*
Posted: Mon May 06, 2013 12:13 pm
by dbarrans
Ok, point made. I didn't really know what github was until you motivated me to go look at it a bit more.
I've been using RCS for almost 19 years so I'm more familiar with it and have evolved my own way of using it with the help of coworkers. I'll take a closer look at github.
- dan
Posted: Tue May 07, 2013 10:15 am
RCS is a step up from SCCS, but not by much. *laughs*
You'll really like git. It's got a ton of great features and is very, very cross-platform.
Posted: Tue May 07, 2013 11:52 am
Whats up with all this secret code words like git, RCS..................
Those "words" mean nothing to us clueless non secret code people.
Is git short for gittyup like the old cowboy movies? :mrgreen:
Posted: Tue May 07, 2013 12:21 pm
by dbarrans
Google means the end of secrets.
http://www.lmgtfy.com/?q=rcs
http://www.lmgtfy.com/?q=git
- dan
Posted: Tue May 07, 2013 5:18 pm
I was simply trying to add a little humor, I know how to use Google and use it a lot.
My attempt at humor was not to be taken seriously. A good day to all! :P
