Repetier-Host EEPROM Config for Rostock Max
Posted: Mon May 06, 2013 5:14 pm
by oxident
My default EEPROM settings in Repetier-Host V0.85b seem to be all over the place. Can anyone send me a screen shot of the settings that are working well for them?
Re: Repetier-Host EEPROM Config for Rostock Max
Posted: Mon May 06, 2013 8:20 pm
by elqisqeyano
oxident wrote:My default EEPROM settings in Repetier-Host V0.85b seem to be all over the place. Can anyone send me a screen shot of the settings that are working well for them?
Upgrade to Repetier Host Version 0.99 and I will send you my settings.
Posted: Mon May 06, 2013 8:48 pm
by cambo3d
where are you getting repetier host .99?
i only see 85b on the website
http://www.repetier.com/download/
Posted: Mon May 06, 2013 9:43 pm
by elqisqeyano
I'm sorry, It is 0.85, I was thinking Slic3r. Here are my EEPROM settings, just double check before you run. Mostly all good, just having some issues with PID tuning and the fact that in the EEPROM the extruders are numbered as EXT 1 not sure if this should be changed to EXT0. Awaiting confirmation of this on another thread I have in the Troubleshooting section.
Posted: Mon May 06, 2013 10:27 pm
by cambo3d
are you using the rambo1.1b, if so you need to double check all your eeprom settings.
i'm using ext 1 on mine and it works, dont know why there label differently. maybe polygon can jump in here and tell us why.
Posted: Mon May 06, 2013 10:33 pm
by elqisqeyano
cambo3d wrote:are you using the rambo1.1b, if so you need to double check all your eeprom settings.
Yes, I have Rambo 1.1b. I purchased the kit a month ago and a half ago.
Posted: Mon May 06, 2013 10:48 pm
by cambo3d
then your all your steps are wrong. unless you have a different pulley. are you using the 20 tooth pulley?
Posted: Mon May 06, 2013 10:51 pm
by cambo3d
do you have the 20 tooth pulleys? and rambo 1.1b?
Posted: Mon May 06, 2013 11:24 pm
by Flateric
He must be, because the steps per mm is correct if using a 20 tooth pulley is it not. The older metal pulley is 106.67. So this would be the only way it could be working and spitting out hugely inaccurate scales of objects.
Posted: Mon May 06, 2013 11:36 pm
by cambo3d
Flateric wrote:He must be, because the steps per mm is correct if using a 20 tooth pulley is it not. The older metal pulley is 106.67. So this would be the only way it could be working and spitting out hugely inaccurate scales of objects.
yeah, what i was trying to get at was, his config may or may not work with original posters setup.
Posted: Tue May 07, 2013 1:07 am
by elqisqeyano
cambo3d wrote:then your all your steps are wrong. unless you have a different pulley. are you using the 20 tooth pulley?
20 tooth pulley yes.
Posted: Tue May 07, 2013 6:51 pm
by oxident
[/quote]
Here are my EEPROM settings, just double check before you run. Mostly all good, just having some issues with PID tuning and the fact that in the EEPROM the extruders are numbered as EXT 1 not sure if this should be changed to EXT0. Awaiting confirmation of this on another thread I have in the Troubleshooting section.[/quote]
Thanks for the settings. I'll give it a shot.
Posted: Tue May 07, 2013 7:25 pm
EXT0 is the first extruder in the firmware, in the EEPROM menu it's EXT1, there is no issue there other than the naming.
Posted: Tue May 07, 2013 9:18 pm
by elqisqeyano
Polygonhell wrote:EXT0 is the first extruder in the firmware, in the EEPROM menu it's EXT1, there is no issue there other than the naming.
Thanks for clarifying that Poly. Then I will let it be just as it is. It is printing spectacularly. Thanks Poly for this version of Repetier Firmware. Fantastic job you did to improve Rostock performance.
