New j head shows -20c
Posted: Thu May 16, 2013 12:04 am
by bplemmons
Just installed a j head but the thermistor shows -20c, does that have to do with the heater cartridge? do i need to change a setting?
Bill
Re: New j head shows -20c
Posted: Thu May 16, 2013 3:36 am
by bplemmons
I discovered that the bed doesn't heat up now, even hooked up the old head, still shows -20c. none of the red lights come up on the Rambo and I checked all three fuses....... stumped
Posted: Thu May 16, 2013 4:11 am
Nothing will work until you get a reasonable reading from the thermistor. The firmware goes into a fails are mode.
The odds are it's a wiring issue, start by measuring the resistance of the thermistor at room temperature, it should be about 100KOhms.
Posted: Fri May 17, 2013 6:05 pm
by Durandal
I'm having a similar problem with my unit. I got it all together and the hot end reads -20c, bed reads room temperature. I think I might have messed up the leads on the thermistor but can't tell because my multimeter doesn't go that high, it just says open. Does Repetier error when either thermistor is reading way off or just when the hot end is reading off? Can I swap the thermistor leads to prove the hot end one is bad?
Posted: Sat May 18, 2013 4:53 am
by Flateric
Yup, this is a good way to test the components and eliminate thermistor issues being the cause.
Posted: Sun May 19, 2013 2:28 am
by bplemmons
Mine started working, must have been a bad crimp on my disconnect
Posted: Sun May 19, 2013 3:04 am
by cambo3d
glad you figured it out. where did you get your jhead?
Posted: Tue May 21, 2013 4:34 am
by bplemmons
A buddy gave it to me, I think it came from maker shed?
Bill
