Rambo 1.1b config as it is new?
The RAMBo board is finally here, and here's a place to talk about it!
Xavier
Post by Xavier »
I have a stock out of the box Rambo 1.1b and I'm wondering what the config files are. Or how to read them off the Rambo... Or?
Thanks,
X
cambo3d
Re: Rambo 1.1b config as it is new?
Post by cambo3d »
if you got it from seemecnc, it comes preloaded with john olys version of repetier firmware, which is also listed in the downloads section of the website.
Xavier wrote:I have a stock out of the box Rambo 1.1b and I'm wondering what the config files are. Or how to read them off the Rambo... Or?
Thanks,
X
Welcome to the forum!
To read more about reading from the Rambo to see what is on it, I've been told that it cannot be done. See this link: http://forum.seemecnc.com/viewtopic.php?f=37&t=1859
Xavier
Post by Xavier »
Thanks,
Reading the info off the Rambo seems hopeless... Or at least not worth the trouble.
That leaves the old fashion way. Somebody should know what the Rambo ships with and have a copy to share.
Or the other old school way... Just overwrite what's there.
Is it marlin or repetier?
Thanks
X
It is Repetier and the copy SeemeCNC uses is found here: http://download.seemecnc.com/
Xavier
Post by Xavier »
I plan to build a repstrap. Is the firmware the same for a delta and a Cartesian printer with only a change in the configuration.h or is the firmware different?
Got configs for a prusa i3 or similar with and without LCD?
Thanks for the info.
X
foshon
Post by foshon »
For a regular Cartesian you are much better off starting with the normal Repetier firmware. SMCNC's is tweaked for a delta style printer. You can get vanilla Repetier here:
https://github.com/repetier/Repetier-Firmware
Click on the "zip" button, download, extract, and install to your board with arduino.
Purple = sarcasm
Xavier wrote:I plan to build a repstrap. Is the firmware the same for a delta and a Cartesian printer with only a change in the configuration.h or is the firmware different?
X
I'm not sure what is changed in the firmware to used for a delta or a cartesian. I would go to http://www.repetier.com/ and download the firmware and flash the Rambo with that version. It would be set up for a cartesian but you would
have to modify configuration.h to your printer specifics. That would have to be done irregardless of what firmware you chose. I don't have the configs for the Prusa I3, hopefully someone else on this forum would be reading this and have
those configs. There are several forums for the Prusa I3 such as http://dev.forums.reprap.org/list.php?151. If you left a message on those forums requesting the configs I would think that someone on the forum could help you. I wish I
could be more help but I do not have any cartesian printers. There is a Repetier sub forum on here that you would probably get more answers with your Repetier questions. It is located here: http://forum.seemecnc.com/viewtopic.php?f=54&t=1046 The users monitoring those threads should be able to talk to you about the Repetier and what you would need to change. Open a new thread there. Best of luck with your Prusa.
Return to “RAMBo”
