Carriages falls down?
Posted: Thu Jun 06, 2013 5:18 pm
by Unstuck
Hi! I just got the best birthday present ever last month. Have had lots of fun putting it together and only occasionally giggling like a schoolgirl.
I ordered off for some kapton tape to assemble the hot end with, and while I was waiting I figured I'd try to assess how level I managed to get the bed.
Unfortunately, it seems if I get the head too close to a column, something seems to happen. I took a video of it happeninghttp://www.youtube.com/watch?v=qNCkM8xCseIZ (Around :25 in.)
I've tried searching in the forums for a couple of days, but I'm not sure how to describe it.
The dial caliper mounted on the head seems lighter than the hot end, so I don't think it's that. The belt's teeth are intact. It happens almost identically to whichever column I raise the platform up to - it seems unlikely to me that all three steppers are bad.
I'm kinda lost, to be honest.
Re: Carriages falls down?
Posted: Thu Jun 06, 2013 5:34 pm
First of all, love the nick. If your first name was Come, I could _easily_ see this:
Person 1: Who's that?
Person 2: Oh, he's Come Unstuck!
Person 1: *steps back a bit* Um, sorry to hear that, but what's his name?
Person 2: ...
(Well ok, I'll admit it sounds funnier in my head than in a forum post...)
:D
I really don't see anything bad happening there. Is the move back towards the center uncommanded?
Couple of things - what version of the firmware are you using? What kind?(merlin or repetier)
I suggest you take a look at the software & calibration sections of the 2nd edition of the assembly manual.
Posted: Thu Jun 06, 2013 5:39 pm
by cambo3d
turn off the stepper sleep mode in firmware/eeprom, when the steppers go into sleep mode (displays shows steppers disabled) Is when this usually happens.
I had a heck of a time calibrating my z because the steppers would go into sleep mode and cause the z to lower,
this may also be what your experiencing.
note: it never did this when using polygons repetier firmware, it started doing this with seemecnc repetier firmware so its probably just a firmware setting.
Posted: Thu Jun 06, 2013 10:04 pm
by Unstuck
Cambo3d has it! I entered
G1 Z150 x100 y-50
Just like in the video, and the head is still hanging there, five minutes later. Thanks!
The tape arrived this morning, so I'll be assembling the head tomorrow - Then maybe making a giant plastic mess that vaguely resembles a cube. But I don't want to get ahead of myself.
Posted: Fri Jun 07, 2013 10:46 am
by Unstuck
geneb wrote: (Well ok, I'll admit it sounds funnier in my head than in a forum post...)
:D
...I'd never thought of the whole "... Third base!" aspect of this. :)
geneb wrote: I suggest you take a look at the software & calibration sections of the 2nd edition of the assembly manual.
I take it you're Gene Buckle, as in 'Copyright 2012 by Gene Buckle' in the Version 1.17 of the manual I'm currently using?
This is what I get for not checking back for a new manual - after about the sixteenth time trying to get the limit switch wires down the tower extrusion I seriously considered just removing the belt and doing it over - but I got it eventually.
Posted: Fri Jun 07, 2013 1:08 pm
Yep, that's me. One of the reasons for the 2nd edition manual was to sensibly fold in the tribal knowledge accumulated by other builders into the mainline manual.
