New version out 1.1.10b
A place to talk about slic3r software (http://slic3r.org)
Flateric
Post by Flateric »
Lots o neat new things in it.
Thought I would let you guys know.
Re: New version out 1.1.10b
New version of WHAT? :)
Do you have a special download link? The main site still only has 0.9.9 available.
I was teasing him because he REALLY got the version number wrong. :) It's 0.9.10b and is available here: http://slic3r.org/
geneb wrote:I was teasing him because he REALLY got the version number wrong. :) It's 0.9.10b and is available here: http://slic3r.org/
And I got the number wrong too...
Maybe slic3r should just do what I do with my code and start over with 1 :)
More importantly, how do I make this version work inside of Repetier Host? (how to upgrade the built in version?)
aehM_Key
Post by aehM_Key »
Overwrite the Slic3r folder or install the newest Repetier Host.
Wipe is implemented badly: https://github.com/alexrj/Slic3r/issues/1276
Spiral vase (Joris in Cura) is great! Miss it in Kisslicer.
kbob
Post by kbob »
Jimustanguitar wrote:More importantly, how do I make this version work inside of Repetier Host? (how to upgrade the built in version?)
In Repetier Host preferences, you can configure it to use an external Slic3r.
Flateric
Post by Flateric »
aehM_Key wrote:Overwrite the Slic3r folder or install the newest Repetier Host.
I'm with ya on wipe.
But the spiral thing I cannot get to behave at all. It starts great until the bottom of the vessel is complete and then jumps upwards about a mm or so and then strats spiralling upwards from that point extruding into the air rather than close enough for the filament to bond with the layers under it.
timothysvec
Post by timothysvec »
Does anyone know where the vase mode setting is?
Return to “Slic3r”
