OctoPrint - Running (Almost)
Posted: Sun Jun 30, 2013 1:25 pm
After some looking around and being pointed to posts (thanks Eaglesoar, Foshon), I got Octoprint up and running. I'll use this post as a build/test log with it.
For some reason, it all came up the first time. I haven't printed yet; however, the screen shot below shows OctoPrint communicating with the printer.
What you need and where I got it:
Hardware:
7-Port Powered USB Hub (Adafruit)
Raspberry Pi (get the 512K version from Adafruit, http://www.adafruit.com/products/998 )
USB Wireless USB Adapter (Adafruit, it's a tiny thing - you can barely see it plugged into the top of the hub http://www.adafruit.com/products/814)
USB Keyboard
USB Mouse
4g SD Card - formatted with FAT, all of it...
HDMI monitor (or use SSH to remote it if you are familiar with doing that)
Some of you might be intimidated by loading up a new unknown operating system but essentially, you get a Raspbian OS zip file
http://downloads.raspberrypi.org/noobs
Expand (unzip) it to the root of the SD card from your Mac or PC, stick the SD card into the Pi and power it up (after connecting the hub, the Wireless USB adapter, keyboard and mouse into the hub)
Follow Adafruit's instructions on getting the Wireless USB adapter going.
Afterwards, follow the instructions here:
https://github.com/foosel/OctoPrint/wik ... g-Raspbian
The only problem I had was keyboard mapping (and forgetting I needed a USB keyboard. I bought mine at a Frye's for $14):
If you are in the US, depending on the keyboard you use, this version of Raspbian uses a Great Britain keyboard setup. If your "~" doesn't look like that, you'll have to get it set correctly: http://elinux.org/R-Pi_Troubleshooting# ... an_Squeeze
Physical Setup:
Note that I had the PI being powered by the USB port on my Mac. You can easily use a USB phone charger for power or alternatively, run it from 5V power to a male mini-USB plug. Once I have a working hot end (hopefully in a couple of days, I'll let you know how it goes and keep adding to this until I get distracted by something else.
Hardware:
USB Keyboard
USB Mouse
Physical Setup:
