wiring end stop for rambo ?
Posted: Sat Jul 06, 2013 12:03 am
by spart
when i wire my end stop connectors is it the outer pins and skip middle so it lines up too the + s on the rambo board
and for the min and max thing i cant find any info on it to which to use , can some one let me know, just got board today so figuring things out before i do anything thanks
Re: wiring end stop for rambo ?
Posted: Sat Jul 06, 2013 2:03 am
You want the S and - pins to be connected, and use the Max connections.
The + connector is for applying voltage (+5v) to powered endstops, like the reprap discount optical ones. On a snap switch, it would send that voltage into the board and cause bad juju.
Posted: Sat Jul 06, 2013 2:38 am
by spart
thank you that help out big time , start wiring tomorrow
Posted: Sat Jul 06, 2013 7:29 am
spart wrote:thank you that help out big time , start wiring tomorrow
Do you have a copy of the assembly manual?
It is available here: http://www.geneb.org/rostock-max/Rostoc ... -Guide.pdf
Posted: Sat Jul 06, 2013 11:21 am
by spart
other then that, i have my end stops set up for center pin and pin closes to the trigger hing need to know what would be on S and what would be on (-) just trying to get it close as i can do the rest in config i think smile
guys i am am not building rock, i designed and built my own, so some things are very different. you guys seam to have worked with the rambo
more then others, i convert were i have to smile
