Few questions about the rostock
Posted: Mon Jul 08, 2013 5:06 pm
Hi guys,
Been lurking here for awhile now and have been trying to trouble shoot the printer and get it to print reliably. I am still running into a few problems that I'd love some insight into.
Firmware: Repetier Max
Software: Repetier 0.90C
Extruder: Ezstruder
Hotend: Seemecnc hotend with heat cartridge
Bed: Onyx Bed with 24V supply
My biggest issue is probably temperature. I just can't seem to reliably tell what the temperature of the extruder is. I have a contact thermal couple that I stick into the nozzle hole (.5mm hole) to get a temp reading. In order to print reliably without the extruder slipping, I have to take my temperature up to close to 270C as read on the thermal couple. The host software was reading the temperature way low compared to the thermalcouple, so I recently changed the multiplier in the firmware to adjust the LCD/software reading to that of my thermal couple. I get brown spots on my prints from time to time so I know there is something going on with the temperature, but when I try to drop the temp to 230C, the ezstruder would slip and the print turns to crap. I can get semi decent prints with the temp at 275C anything less, i start to see slip in the ezstruder.
Here are a few pictures of my most recent print:
This one is done with kisslice, it has raft/support/and 25% infill.
Extruder: Ezstruder
