If so, what watt/voltage UPS are you using? I know that the power supply is 450w, but does anyone know what the ACTUAL draw is while printing with the bed on?
Mood: Irritated.
My intent isn't to keep the printer going for very long...just long enough for the power to come back on. Outages are not that uncommon by me, but they are very short. Usually less than a few seconds (more like trips/switchovers than true outages). We've lost a refridgerator and washingmachine due to these trips/surges/etc., so a good UPS with surge protection is what I was looking at. It would have saved my print last night.foshon wrote:The issue with a UPS won't be whether or not it can power the printer, most are able to power a computer and it's monitor. The issue is the length of time it will keep it running. Most backups are set up for large output for a short period of time, not long enough to finish a print...
Unlike my wife, whom I continue to disappoint.foshon wrote:Cool, just wanted to make sure you had realistic expectations.
This is exactly what I needed!kbob wrote:The bed is ~110W peak. The hot end is ~40W peak. The motors are maybe 50W (probably less). The electronics are negligible. So 200W is the total load. Power supply is 80% efficient (maybe), so it draws 250W. Oversize that by 50% and look for 375W, or 530 VA. (VA = watts * sqrt(2). sqrt(2) = 1.4.) Bigger is, in this case, better.
