Test Thermocouple
Posted: Fri Jul 12, 2013 3:05 pm
by msdevstep
I really don't trust my thermocouple that I have. Does anyone know an easy way to test the thermocouple to ensure it's completely accurate. I checked it in ice water for 0C, and it got pretty close, but when measuring something around 240C, I still don't trust it.
Re: Test Thermocouple
Posted: Fri Jul 12, 2013 3:41 pm
Are you comparing it against a thermocouple? If not, that's the FIRST step you need to take.
Posted: Fri Jul 12, 2013 3:48 pm
The ice water was good to do. The next step is too bring water to a rolling boil and check with the thermocouple, it should read 100 degrees.
If it passes these two tests, I would assume the thermocouple is accurate. There will be small variations based on the fact that water boils
at slightly different temperatures based on elevation and impurities in the water. We are looking for close here not trying to calculate how to
land a module on Mars.
Posted: Fri Jul 12, 2013 3:52 pm
Thermocouples are inherently accurate (afaik). What he needs to do is compare the values from a THERMISTOR (in the hot end) to the value reported by a thermocouple.
The boiling water/ice water trick is useless when you've already installed the thermistor in the hot end and you don't want to screw it up by removing it, performing a pointless test and then reinstall it.
BUY. A. THERMOCOUPLE.
Posted: Fri Jul 12, 2013 4:07 pm
geneb wrote:Thermocouples are inherently accurate (afaik). What he needs to do is compare the values from a THERMISTOR (in the hot end) to the value reported by a thermocouple.
Gene, he has a thermocouple. He is just trying to determine the accuracy of it. He is not talking about testing the thermistor. Either I or you misread the question.
Posted: Fri Jul 12, 2013 4:55 pm
by cambo3d
I agree with eaglezsoar. I tested my thermocouple meter against 100c boiling water and my temps were not that far off, maybe a degree or two. I never even bothered to do 0c test.
my thermocouple meter manual only suggest to calibrate against 100c boiling water.
Posted: Fri Jul 12, 2013 7:28 pm
My apologies. I keep seeing people doing stupid things with thermistors and it's become my default reaction.
Posted: Sat Jul 13, 2013 10:57 am
by foshon
geneb wrote:My apologies. I keep seeing people doing stupid things with thermistors and it's become my default reaction.
Perhaps we need a "Stupid Thermistor Tricks" sticky?
