So far I've been loving the Rostock Max, its a well designed kit and great features. However, since the beginning I've been having extruder woes, not limited to the hot end jamming, retraction inconsistency, and requiring more force than what seems normal (compared to other 1.75mm hot ends i've had) to extrude through the hot end.
After finally disassembling the hot end to unclog a hotend jam, I think I've figured out the reason for the jamming!
Looking at the Hot end 3D CAD models, the total length of the small 4mm OD PTFE tubing should be 45.59mm long in order to ensure that the filament is fed directly into the hot end nozzle
Measuring the ptfe tube that was in the hot end that I received, I found it to be 40mm long. Thus there was a 1.5mm gap creating volume for the ABS to squeeze into and sit around, rather than directly extruding the nozzle.
Here is a diagram showing the gap, as well as what the proper length of the PTFE tubing.
[img]http://colin-ho.com/wp-content/uploads/ ... oblem1.png[/img]
Heres the picture of the length of the PTFE tubing I got with my extruder
[img]http://colin-ho.com/wp-content/uploads/ ... .14.16.jpg[/img]
Lesson learned: don't assume the hot end was assembled perfectly, take it apart and inspect the PTFE tube length and make sure there aren't any gaps!
Another problem I found was that the PTFE tubing was that a bit of it was crimped down on the end facing the nozzle, thus creating a corresponding dent in the PEEK piece.
[img]http://colin-ho.com/wp-content/uploads/ ... .16.57.jpg[/img]
Corresponding indentation in PEEK
[img]http://colin-ho.com/wp-content/uploads/ ... .17.52.jpg[/img]
I suspect that this may have enabled the ABS to initiate its creep into the gap, and the eventual pressure of the filament shoved more molten ABS into the gap further widening it.
I Hope this helps for others with hot end issues!
