Basic Modifications Roll Up For New Builders
Posted: Thu Jul 18, 2013 1:13 pm
Doing a quick catalog (rollup) of possible mods to enhance or overcome design opportunities:
(Caveats: These are what I would call minimums or low investment items in terms of cost and time.)
In no particular order:
1. Magnetic Arms or Carbon Fiber with swivels arms smooth out prints.
2. A peek fan is mandatory for PLA and helps with reducing potential hot end jams. The peak fan may affect printing with higher temp materials. You'll need a peek fan shroud and 25 mm fan (see seemecnc site). You may also want to print PLA and in that case, a larger shroud and 40 mm or so fan. Lots of shrouds on Thingiverse.
3. A 25mm fan inside the electronics section pointed at the steppers helps with circuit stabilization due to potential heat issues.
4. Some have reported Smart LCD panel issues due to noise - a potential solution is to shield the ribbon cables or use very short ones.
5. Some folks have enhanced the end stop screw mechanism to provide better indicators for calibration. I use 2" 6/32 Hex head screws but others have put pointers and more advanced tuning mechanisms.
6. Borosilicate glass helps even out heat issues. Others have added other heated bed parts - even external heating devices.
7. Quiet down your prints with a thin sheet of cork or other dampening material (or part) between the stepper motor and the frame. Parts are available on ebay or cut your own. Use a 12mm screw instead of the stock one to accommodate the extra thickness.
8. Alternate hot ends might be your next step....
Doing a quick survey on this list, you're under $150 to put some icing on the Rostock Max cake.
Search the forum for various links that may help you with these items.
Printmasters, are there any other basic mods that you would add here?
