Damn you shrinkage! (trivial I know)
lordbinky
Post by lordbinky »
So on a hollow cube ( .2mm layers, abs) my first layer prints spot on, a 10 mm cube is 9.97, then you go up 20 layers and the plastic pulls in so the cube is ~9.82mm. Everything is lined up, no skewing, good adhesion on layers, good adhesion to the bed...the only thing is that it contracts as it moves away from the bed (it is consistant after that). Is there anything to change to counter that effect?
kbob
Re: Damn you shrinkage! (trivial I know)
Post by kbob »
lordbinky wrote:So on a hollow cube ( .2mm layers, abs) my first layer prints spot on, a 10 mm cube is 9.97, then you go up 20 layers and the plastic pulls in so the cube is ~9.82mm. Everything is lined up, no skewing, good adhesion on layers, good adhesion to the bed...the only thing is that it contracts as it moves away from the bed (it is consistant after that). Is there anything to change to counter that effect?
I think you need to set your infill to 60% or so. (-:
astroboy907
Post by astroboy907 »
No offense but your avatar is the perfect representation of this post... :P
Flateric wrote: Black ABS, weak part, bizzare holes, bad layer adhesion, loss of details. Loss of sanity.
My Heatware!.
lordbinky
Post by lordbinky »
Hmmm.... Nope, don't see it. :shock:
lordbinky
Post by lordbinky »
Psh, but then it wouldn't be a hollow cube.
