EX Pid gain
Posted: Mon Jul 29, 2013 7:53 pm
by jmick
In the assembly instructions it states that after the hotend test is run to take the pid-gain test results and average the 3 printout results and insert them into the Eprom in lieu of what is already there. My problem is where is the log window data stream that is supposed to print out in Host. The only log window I have on Repetier Host is in the lower left and that is only one bar which always has the temperature in it. Where is all the rest of this data that is refered to in the assembly instuctions as in the log window. Where is this window with all this information?
Re: EX Pid gain
Posted: Tue Jul 30, 2013 12:36 am
by lordbinky
where it says:' Show in log ( )Commands ( )Info ( ) Warnings ' ...... etc. you should be able to click the separation bar (your mouse turns into a bar with an arrow up and arrow down on it) and drag the window up to increase the view of the log window.
Re: EX Pid gain
Posted: Tue Jul 30, 2013 1:43 am
by jmick
Thank you lord, I have been trying to get that answer from support for over a month. You made my day.
