Extruder stepper motor does not work - why?
Posted: Tue Jul 30, 2013 11:38 am
Hi,
Im setting up my IndigogoPerk-RostockMax (Yes very late!:)). Its the first time I touch a 3D printer and all that comes with it...
Everything in the setup/calibration process (all movements of the delta arm etc) has worked good so far (updated Firmware to RepetierMAX 0.80 (and set what I think is correct settings in the configuration as I have a RAMBO 1.0) but:
I cannot get the extruder stepper motor to work. It is not moving when jogged (in Repetier-Host Mac 0.53) just "vibrating"... What can be wrong??
If I change the extruder motor connector to one of the XYZ-motor outputs it works as good as the other motors.
Is it a hardware problem with the board or only a configuration that I have missed? Or just me being a dumb user missing something obvious in the GUI? (I've tried to use the second extruder output, but I have likely done something wrong as nothing with the motor happens)
A small clip can be found at:
http://youtu.be/PYwemw-oAxw
The following are my EEPROM settings:
And printer settings:
Thanks for anything getting me started to make my first prints!
/Markus
/Markus
