I was wondering if anyone knows if I can use the Rostock MAX Firmware on the delta mini (the printer that its STLs are available on the Thingiverse). I belive it's the same as the MAX but abit smaller -(using the components, like belts, wheels and motors) similar to the MAX will make things easier to get and build!
Thanks
Delta Mini 3D Printer
Altarke
Rostock MAX V1 Printer
Re: Delta Mini 3D Printer
Yeah, although you will need to modify Configuration.h and tell it all of the specifics.
.. And would you know what specific info is that, or the better questions is - if I am new to 3Dprinting, will I know what to change ?626Pilot wrote:Yeah, although you will need to modify Configuration.h and tell it all of the specifics.
Thanks
Altarke
You will have to read the config.h it is commented so you know where they derive their values. There will be many small changes and it's helpful to know your part sizes in advance.
I wonder if anyone already has this all ready made - it is after all a well known printer that made a name for itself...lordbinky wrote:You will have to read the config.h it is commented so you know where they derive their values. There will be many small changes and it's helpful to know your part sizes in advance.
Thanks
Altarke
