G28 z-axis on RAMBo not responding?
bubbasnow
Post by bubbasnow »
First off i did a search on "G28" and i couldn't find anyone with my exact problem I'm experiencing.
Just got the Rostock Max assembled and starting doing ch 17 in the ver2 pdf
I configured my Repetier as closely to the books as possible, I am running ver 0.90c and the "connection" tab under printer settings is a little bit different
I get to the part where you enter g28, the x and y started going down and the z remained still.
I found and made true the inverse parts in "configuration.h", ran g28 again the x and y are now going up but the z still remains still
I swap x and z connection on the board, run g28 again and z and y go up and x remains still
Although my servos shipped with the connectors installed a checked, and with that switch test i performed it proves that the connectors themselves aren't the problem
I return the connectors back to the correct location on the board, and try to move z in "manual control" tab, i just get a bunch of humming and no motion.
I imagine i could test the second z motor port on the board but i am unsure where to configure that.
Thanks for the input in advance
bubbasnow
Re: G28 z-axis on RAMBo not responding?
Post by bubbasnow »
after talking to support today, they suggested that i swap z pin assignment with e1 pin assignment in "pins.h"
so i went down to the mega2560 and changed the following:
#define Z_STEP_PIN 33//35
#define Z_DIR_PIN 42//47
#define Z_MIN_PIN 10
#define Z_MAX_PIN 30
#define Z_ENABLE_PIN 25//27
#define Z_MS1_PIN 63//68
#define Z_MS2_PIN 64//67
#define E1_STEP_PIN 35//33
#define E1_DIR_PIN 47//42
#define E1_ENABLE_PIN 27//25
#define E1_MS1_PIN 68//63
#define E1_MS2_PIN 67//64
then I compiled and uploaded it, but it still doesn't work. do i need to change anything else where?
bubbasnow
Post by bubbasnow »
When I mapped the z pins to e0 it worked.. Looks like something fishy is up with my Rambo.
jmick
Post by jmick »
Most problems with the stepper motors are a result of crimping improperly, unless you have a rachet type crimping tool you are
not going to get good tight crimps.
http://www.amazon.com/HT-225D-Cycle-Rat ... 3KK758WMXQ
foshon
Post by foshon »
Did you check the state of the z-axis limit switch? If it is showing made the axis will think it is home and not move.
Purple = sarcasm
bubbasnow
Post by bubbasnow »
John tested my rambo, z was having issues. replacement board has been shipped to me.
Thanks All!
m4r1n5
Post by m4r1n5 »
Am I in the same boat? even when I switched with another motor, that motor did the same thing when I ran g28:
[youtube]http://www.youtube.com/watch?v=9PFLt1DlOd8[/youtube]
bubbasnow
Post by bubbasnow »
when you connect to your rambo and repetier host software, are you able to run the extruded stepper motor back and forth to feed line?
I found that the e0 slot is a perfect way to test to see if your stepper motors for x,y,z are wired properly and have good connection.
In my case, just the z drive was not approaching the limit when i ran the g28 code, the x, y hit the limit and stopped like they were supposed to.
when i watch your video it doesn't even look like they make it all the way up.
