Scaling mishaps
Posted: Sun Aug 18, 2013 7:15 pm
by theverant
So I print off the 20mm cube as per Polygonhells directions. My wall thickness seems spot on @ .55mm, but my xy scale seems to be consistently %3 off (cube comes out a pretty uniform 19.5mm). Is this a problem, or is this normal shrinkage?
Re: Scaling mishaps
Posted: Mon Aug 19, 2013 11:41 am
by lordbinky
That's normal shrinkage. When I measure my test pieces anywhere that doesn't include the first layer, they will be about that much off. If I have that first layer in my calipers my am usually within a .03 mm.
edit: For ABS....
