Custom Parts seem small
Posted: Mon Sep 02, 2013 11:36 pm
by camais
Hey, I attempted creating a support bracket for my bookshelf. The part was designed to be 55x30x12 mm. However, when I load it into Repetier, the part seems way too small, especially compared to other existing parts I have made. Anybody know what I might be doing wrong?
Re: Custom Parts seem small
Posted: Tue Sep 03, 2013 2:54 am
When I load it into Netfabb, each dimension is one tenth of what you said they should be.
It appears that your scaling is off by one tenth on whatever program you used to produce this part.
Posted: Tue Sep 03, 2013 9:36 am
I see this when models are created using a centimeter scale instead of a millimeter scale.
Posted: Tue Sep 03, 2013 8:41 pm
by camais
Thats odd... I used Autodesk Inventor and made sure to select mm parts. Well at least I know the easiest fix is to scale x10 it in repetier.
Thanks guys :)
