Power cycling the printer to get it out of dry run mode seemed to fix it 90% of the time. Once or twice I had to power cycle it again. Thermistor kept reading correctly on the meter. I tested the circuit up to the thermistor bulb itself and back down to the board at every junction and everything looked good.
I had several failed prints yesterday where it would throw a temperature sensor error and go into dry run mode in the middle of the print; at one point I saw a temp reading on the hotend of -20C. Besides THAT, the printer was otherwise running fine when I shut it down and left it that way for the evening.
Turned it on this morning - didn't change a thing - and now the LCD screen on the RAMBo doesn't show anything except four rows of white squares.
HELP
--EDIT / Update--
I've narrowed it down to the hotend thermistor lead. When it is unplugged, the printer boots normally and the LCD display functions, although I get "def" readings for the temps on the hotend AND bed. When it's plugged in, white squares and nothing else. I haven't changed a dang thing since it was working mostly properly yesterday
I'm stumped. Still could use some help here.
