new guy build
Posted: Sun Sep 08, 2013 3:55 am
I have been researching what type of 3d printer to build for a while and went with the rostock max as i love the delta look and print size it offers. This was after looking at mendalmax and eventorbot also.
So far I have printed the parts using our makerbot 2 at work that I can, including the greg's wade's extruder mod that I found on thingiverse. I have constructed carbon arms with magnetic ball ends, these are adjustable length for very fine tunning. i have had the frame cut from a very cool acrylic, and think I will end up going with ramps 1.4 for the electrics.
As far as hot end goes i want to try with the e3d hotend as from what i read it seems to be a nice reliable part. i have modded a wire brush end into the extruder to clean the hobbed bolt as it rotates, i also made the hobbed bolt at work and this system is to prevent slippage, it includes a small {5mm} draw fan to clear debris released by brush.
I am doing this on a very tight budget as are most builders, and it is that reason i was leaning towards the ramps, a cost based decision. I purchased through a work supplier some good bearings and have been lucky to have had access to free bolts throughout the build, I just dont want to be buying more electrics or a different hot end ect.
I have read through the forum for a few months now getting tips here and there but now want to ask if there is anything that stands out as a bad decision or pitfall in my build plan.
The one thing i am wanting advice about the most is the bed and heating parts. what are the best and most reliable that people can recommend thus far, i understand that opinions differ but the cream also rises to the top.....
also i have noticed people having bed leveling issues, I have a 3 decimal digital level i was going to use throughout the build, has this method been used? if so was it workable?
Thanks all for any help I appreciate it.
Go easy on the new guy.
