Need help for a beginners in the set-up phase.
We are still working through the manual.
The X and Y are reading at +135 (mm?) in the repetier-host manual tab yet they are centered. We had to reverse the first two pins of each axis motor connecter to get it to move up on a G28.
What needs to be changed? Pins? Something in the arduino program?
We are soooo close...
X,Y are reading at Max limit + but they are centered
Re: X,Y are reading at Max limit + but they are centered
so when you g28, it goes up then rests?
the g28 centers it but the numbers read 135
Your configuration of Repetier itself isn't correct. Look in the manual - (hint - look at how the end stops are configured in Repetier)
