I want all of this.
Posted: Wed Sep 25, 2013 12:12 pm
by daftscience
[youtube]
http://www.youtube.com/watch?v=t3O19n_JqXU[/youtube]
I started watching this for the pancakes, then noticed the insane tool changer.
Re: I want all of this.
Posted: Wed Sep 25, 2013 3:06 pm
by krak
That was an interesting use of the tool changer as well as a quick probing routine. It makes me wonder how far off the EZ probe development is.
Posted: Wed Sep 25, 2013 4:18 pm
So far it's dead in the water at the moment. The developer hasn't had any free time to hack on it.
The auto-level code in Merlin and the Repetier .90 Beta only account for bed level. If you've got your DELTA_RADIUS calibrated perfectly, auto-level would have some value I suppose.
Don't confuse auto-level with auto-radius. Auto-level doesn't do delta printers much good without a perfect DELTA_RADIUS setting.
Posted: Wed Sep 25, 2013 4:40 pm
by krak
Well that's not the news I hoping to hear. I wonder if the user in the youtube worked on any radius calculations in the probing routine since the bottom of a frying pan is not normally flat.
Posted: Wed Sep 25, 2013 5:30 pm
Considering he was pumping a liquid and his layer height was probably about 3mm, I don't think he had much to worry about.
Posted: Wed Sep 25, 2013 5:42 pm
by lordbinky
Psh, not using a flat frying pan? Everyone knows real chefs use cast iron lapping plates for their cooking surfaces.
Posted: Wed Sep 25, 2013 9:08 pm
by 626Pilot
What a delicious mod.
Posted: Thu Sep 26, 2013 11:07 am
by krak
geneb wrote:Considering he was pumping a liquid and his layer height was probably about 3mm, I don't think he had much to worry about.
You're crushing my hopes and dreams, Gene. But actually, I don't seem to have a problem with leveling, hieght, or radius. I seem to continue fighting the extruder to give me good prints. Even after your sticky guide. Find a way to automatically dial those setting in, and you'll be in the money.
Posted: Thu Sep 26, 2013 12:14 pm
by cope413
krak wrote:geneb wrote:Considering he was pumping a liquid and his layer height was probably about 3mm, I don't think he had much to worry about.
To do so would require a way to measure your filament as it's going into the extruder, as well as a way to measure the amount of pressure being applied to the filament against the hobbed bolt... probably not going to happen any time soon in a cost effective form.
Find good filament (I like MatterHackers' stuff) and keep it consistent and your extrusion issues should resolve themselves
