I have a makerfarm hot end and no matter what temp I set it too, the hot end comes up about 1-2 deg. short, keeping the printer from starting the print.
I have ran the pid tune several times and even though the exact thermistor isn't shown on the tables I have tried the common ones..
Isn't there a deviance tolerance setting that would allow that printer to start?'
Bill
Temperature always 1 deg. short of target
Re: Temperature always 1 deg. short of target
Turn up P a bit and reduce D a bit.
You can also try messing with the PID drive max and min values.
Auto PID is not always ideal.
That did it.
you da man!!
Thanks!!!
Bill
you da man!!
Thanks!!!
Bill
