stepper motor failure
Posted: Sat Sep 28, 2013 10:52 pm
Hey,
I feel like im blowing up the board today, but have finally been able to spend a lot of time with the rostock. So today I've managed to print around 5 prints, most coming out pretty well. Tonight, I started to print another, and the X axis stepper motor simply stopped. I tried switching the X and Z axis motor leads to see if it was truly the motor, or something electrical. When I switched the leads, the X axis stepper worked fine, and the Z axis was dead. I also tried reinstalling the " device driver" and resetting the board, as well as using several different computers, disconnected and reconnecting the machine etc to repetier. So....
This leads me to believe several things
1. The X stepper motor works fine
2. The wiring itself to the motor works fine
3. There could be a problem in the board?
4. There is some communication issue, that is telling the x axis port to " work". ( maybe in board? )
Thanks so much for any thoughts!
