Iron man hand - ABS
Posted: Fri Oct 18, 2013 2:43 pm
Full sized ABS Iron Man hand for a client...
Sliced with KISSlicer
0.5mm nozzle
0.2mm layers
skin thickness: 1.5mm
loops: 3
25% infill
seam hiding 0.6
Bed temp 100*C, hot end 245*C, but only maintaining around 243*C (pushing the upper limit for PEEK)... I really need an all metal, LOL
"fine" support for angles over 55 degrees @ 0.4mm gap
destring:
prime/suck 5, wipe 9
speed 150mm/s
min jump: 1.5mm
trigger: 5mm
Took about 20 hours to print!
Base supports because the bottom wasn't even flat!
[img]https://lh3.googleusercontent.com/-mL-U ... 017_210336[/img]
[img]https://lh6.googleusercontent.com/-IT5_ ... 017_224001[/img]
[img]https://lh4.googleusercontent.com/-KD1T ... 018_095546[/img]
[img]https://lh6.googleusercontent.com/-t2zc ... 018_141750[/img]
[img]https://lh4.googleusercontent.com/-uvvJ ... 018_150232[/img]
[img]https://lh3.googleusercontent.com/-802b ... 018_150245[/img]
[youtube]http://www.youtube.com/watch?v=KDQZF7kRpls[/youtube]
More photos:
https://plus.google.com/photos/10915024 ... 4uvx8z2-gE
0.5mm nozzle
0.2mm layers
loops: 3
25% infill
seam hiding 0.6
destring:
speed 150mm/s
min jump: 1.5mm
trigger: 5mm
More photos:
