The oddest thing just occured. Repetier reset all values.
Posted: Sun Oct 20, 2013 9:25 pm
The absolute oddest thing just occured after using my print for the entire day.
Started up my 5th print of the day.
And the hotend only moved exactly halfway down.
Check my firmware settings and they have selectively reset themselves to default......or something.
My steps per mm went from 160 to 80, should be 160.
My radius went from 133.789 (very carefully tuned this for hours) to 75.00, should be 133.789.
Acceleration for print and travel went from my previous setup to 2500 and 5000, and I had much different values in here.
My jerk went from 50 to 20.
My tower x y z offsets all reset themselves to zero.
My PID values for the heated bed and hotend are no longer the values I set them as.
I do NOT have the arduino utility even loaded.
I did absolutely not one thing between the end of one print to the start of the next. I was sitting here when the print ended, backed my filament off, put down some new blue painters tape, pressed it down, alcohol wiped it....
Hit print and everything is reset.
Anyone able to tell me how this could happen?
No one else around, this is a total mystery to me in every way shape and form. It simply should not be possible as far as I can tell. If I were reading this I would immediately assume the person typing it must be mistaken, but I can assure I am not. How!!????.....
