is there a extra connection on rambo for fan
Posted: Tue Oct 22, 2013 2:44 pm
by spart
iam looking for a way to plug in a extra fan for extuder motor on rambo board lost my instuction sheet. see that there is a extra 5v connector on board but not to sure how ya control it any one know
Re: is there a extra connection on rambo for fan
Posted: Tue Oct 22, 2013 2:55 pm
If you want to run a 5V fan all the time, just grab a red and black wire off the power supply and do it that way.
Posted: Tue Oct 22, 2013 3:05 pm
by spart
just saw that my fan that i got is 12 v lol
Posted: Tue Oct 22, 2013 3:08 pm
spart wrote:iam looking for a way to plug in a extra fan for extuder motor on rambo board lost my instuction sheet. see that there is a extra 5v connector on board but not to sure how ya control it any one know
If you are talking about the two pin connectors, there should be two of them, labeled on the schematic as Aux Power connectors.
One will provide 5 Volts, the other will supply the voltage equal to the input voltage (normally 12 volts). As far as I know you
cannot control these Aux power connectors from the firmware, they are always on. They can be used for a 5 volt fan the other
for a 12 volt fan but these fans will always be on when the Rambo is powered.
The Rambo wiki is here:
http://reprap.org/wiki/Rambo
Posted: Tue Oct 22, 2013 3:19 pm
by spart
thanks i will give them a try
Posted: Wed Oct 23, 2013 2:56 pm
by dsnettleton
Or do what Gene said with a yellow wire instead of red.
