My Solidworks Files
Posted: Thu Oct 24, 2013 8:10 pm
by bubbasnow
i got 2013 up and running on my windows 8.1 machine.
Ill upload things I make to this google drive folder.
Has anyone else made anything cool?
https://drive.google.com/folderview?id= ... sp=sharing
Re: My Solidworks Files
Posted: Thu Oct 24, 2013 9:19 pm
by bubbasnow
breadboard mount.sldprt uses this board, and mounts it at an angle and fits into the open slots between x and z. its also close to the power supply extra wires so you can bring up power for electronics.
http://www.radioshack.com/product/index ... Id=2734155
fanmount and rambomount.sldprt are a fan + spacer for rambo. i used an old xbox fan.
mm3.sldprt is a scaled outline to the minuteman 3 ICBM rocket i found in a newspaper on base here.
screwend.sldprt is something i made to sit on the adjust screws, so it always presses on the same spot on the micro switch. I was having issues where a quarter turn the head of the screw would hit the switch in a different place...which would cause me pain. while calibrating after you turn the screw just slide it back over the head and adjust again
