EZstruder slipping, grinding filament One Solution
Posted: Thu Oct 31, 2013 7:18 am
I had a pg microstuder mounted to my machine awhile back. I switched to the EZ to give it a shot and it worked great, so the pg went to another machine. While poking around in the firmware I noticed that my current setting for the extruder was still set very low for the pg. At the time I was having some trouble with a spool of silver filament (read: junk that will not run consistently with any settings) so I upped the value to the same number as the rest of my motors.
I dealt with the junk filament for awhile and finally gave up on it . Moved back to some more stable stuff and my prints started suffering from persistent extrusion issues. There had been a month or so between the junk filament and switching to the good stuff, we were moving the in-laws and stuff. After cleaning my nozzle, upping the temp, and cleaning the drive wheel teeth more times then I care to talk about, I finally remembered the one firmware change I had recently made.
I was running the EZ at the default current (135, 150?) I decided to drop it back down a bit to see if it made any difference at all. Yup That got it, no more mid print popping, no more shavings in the block. I dropped it to 120, btw.
