repetier looses extruder heat visibility
Posted: Wed Nov 06, 2013 12:41 am
by sunkenbier
Ive been playing with my Rostock max in repetier. When running a print job it heats the bed then it heats the extruder. I can see on the rostock lcd panel that the extruder is heating but in the repetier software it tracks the temperature for 10 to 20 degrees than just keeps that temp. The Rostock LCD itself shows that the temp is reached but my prints are not starting. Anyone know what setting I have set wrong?
Re: repetier looses extruder heat visibility
Posted: Thu Nov 07, 2013 7:27 pm
by Mhagan
can you use the SD card to print? This sounds similar to what happens to me when I disconnect the USB cable. From that I am guessing that your Serial is cutting out.
Posted: Sat Nov 09, 2013 10:32 pm
by sunkenbier
Found the issue. It was a mistype on my start g-code. I had typed G1 Z3000 F300 instead of G1 Z300 F3000. Track down where it was hanging by using the echo on.
