Advice needed
Posted: Thu Nov 14, 2013 8:07 pm
by Toyguy
I'm just finishing installing and squaring my towers and I am finding it difficult, if not impossible, to get an even gap on the 3 legs at the base. Essentially, when square, the towers have no gap at all on 2 sides and only the slightest on the other. There seems to be no in-out movement available when they are loosened enough to move.
I'd appreciate it if some of you veterans would take a look at these pics and let me know if I need to keep trying to adjust this. I am tempted to call it good and move on.
X Tower:
[img]
http://i243.photobucket.com/albums/ff27 ... ce5283.jpg[/img]
Y Tower:
[img]
http://i243.photobucket.com/albums/ff27 ... 979dde.jpg[/img]
Z Tower:
[img]
http://i243.photobucket.com/albums/ff27 ... e55391.jpg[/img]
Re: Advice needed
Posted: Fri Nov 15, 2013 12:03 am
by Flateric
This is looking pretty darn good to me personally.
Re: Advice needed
Posted: Fri Nov 15, 2013 2:50 am
by Sonrisa3D
In my experience Gaps are the least of your worries. Concentrate on squareness. It helps to make sure each of the three pilars are equidistant from eachother, there is a fixture on thingaverse that can help.
Re: Advice needed
Posted: Fri Nov 15, 2013 5:04 am
They look fine. What is important is that they are perfectly square to the base.
Re: Advice needed
Posted: Fri Nov 15, 2013 8:52 pm
by 626Pilot
Re: Advice needed
Posted: Fri Nov 15, 2013 9:15 pm
Do you think a band clamp would accomplish the same thing?
Re: Advice needed
Posted: Fri Nov 15, 2013 9:48 pm
This one time, at band clamp.....
Re: Advice needed
Posted: Fri Nov 15, 2013 10:20 pm
geneb wrote:This one time, at band clamp.....
Not sure what that means Gene, a band clamp wouldn't work? I wasn't sure but it seems it would do the same job as the printed clamp.
Re: Advice needed
Posted: Fri Nov 15, 2013 10:29 pm
by Toyguy
It's a pop-culture movie reference
Re: Advice needed
Posted: Fri Nov 15, 2013 10:33 pm
Toyguy wrote:It's a pop-culture movie reference
Went right over my head, guess I don't get out much.
Re: Advice needed
Posted: Sun Nov 17, 2013 5:22 pm
by TFMike
Re: Advice needed
Posted: Sun Nov 17, 2013 10:18 pm
by 626Pilot
Just about! I'd definitely try a couple of those if I had any. I assume you mean the strap that clamps to itself and ratchets down, like a furniture mover would use?
Re: Advice needed
Posted: Mon Nov 18, 2013 4:55 am
The band clamps that I have are made for woodworking, here is a link to what I mean:
http://www.amazon.com/15-Ft-Ratcheting- ... band+clamp
I would put it around the uprights and tighten, in my mind it would seem to accomplish what the printed clamp does.
EDIT: After thinking about it some more I do not feel the band clamp would work the same as the printed clamps, the printed clamps allow you to tweak each upright
separately, the band clamp would not give you that flexibility. I have printed out the clamps now I need to buy some threaded rod.
