RAMBo SD Fan1 issue
Posted: Fri Nov 15, 2013 1:01 am
by bubbasnow
so im printing for sd card and i cannot get RAMBo to turn on the fan 1 with the m42 p6 s255... does this not work from sd?
Re: RAMBo SD Fan1 issue
Posted: Fri Nov 15, 2013 3:53 am
by ccavanaugh
Are you using repetier? If so, there is an EXT0 option that let's you specify a pin to be turned on when the extruder is turned on. I'm not sure if it's accessible through eprom settings.
Posted: Fri Nov 15, 2013 12:44 pm
by bubbasnow
.80 rostock max version yes. M42 p6 s255 works egged I send it from host but just not when it's from sd card
Posted: Fri Dec 06, 2013 6:48 pm
by Lochemage
Are you literally using "m42 p6 s255", or are you using "M42 P6 S255"? Capitalization does matter in Repetier Host, unlike Pronterface.
