68377 TSLOT SUPPORT
Posted: Sun Nov 17, 2013 7:43 pm
by Tincho85
Hello guys, I think I've found a problem with the WOOD RMAX EZ SHEETS files.
The "68377 TSLOT SUPPORT" seems to be wrong. I still haven't build my Rostock yet, but was checking the laser cut tolerances when found this.
If someone could check this would be great.
Here are some pics, images speak better than words :P
Re: 68377 TSLOT SUPPORT
Posted: Sun Nov 17, 2013 7:47 pm
by Tincho85
The 3 supports
The 3 supports on top of each other
Close up
68377 03.jpg (33.27 KiB) Viewed 4976 times
Posted: Sun Nov 17, 2013 9:51 pm
by Toyguy
Gene notes this in the manual. Those rounded areas don't impact anything, the fact that they are different is merely cosmetic. Do a dry fit of the components and you'll see what I mean. Mine were like that too.
Dave
Posted: Sun Nov 17, 2013 10:14 pm
by Tincho85
Toyguy wrote:Gene notes this in the manual. Those rounded areas don't impact anything, the fact that they are different is merely cosmetic. Do a dry fit of the components and you'll see what I mean. Mine were like that too.
Dave
My mistake for not reading the manual.
Thank you Dave.
