Newbie questions + Video
Posted: Fri Nov 22, 2013 5:47 pm
Got my ORION this morning and due to lack of time before work, I deviced to just try a test print... Yes, without ANY Z-calibration or any calibration of any kind. Just plug the printer in and hit "print"
I'm very impressed that it actually seems to be working:
https://www.youtube.com/watch?v=pEnaR1BmU_E
Kudos to SeeMeCNC for making a truly "PNP" printer, that's still open source and tinker friendly at the same time!
Alsight, here come the newbie questions:
1. How do I clean the glass plate? Do you take it off for cleaning or just wipe it down in place?
2. There seems to be no fan/shroud on the extruder? Am I just not seeing it or is it simply not required for mostly ABS prints?
3. I'll do the Z-level calibration tonight. Anything else I need to calibrate?
4. Do I need to remove the filament from the extruder after printing or simply leave it in there primed for the next print?
5. How do you stop a print in progress? I found "pause print" in the SD card menu, but it doesn't seem to be a hard "stop"?
6. The printer seems to make a knocking sound. I think when it moves all three axis to raise up a layer. Is this normal (see video)?
7. Anything else I should know, start reading up on?
