Anyone know what the approximate room-temperature resistance for the bed thermistor would be? I installed mine last night and I'm going to meter it from the pads on the outer edge to make sure it isn't shorting against itself or the hole in the bed. Obviously an infinite or zero will be a problem, but I'm wondering what to expect normally.
Dave
Bed Thermistor resistance
Re: Bed Thermistor resistance
Both thermistors should be about 100K ohms at room temperature.
The bed itself will be under 2 ohms.
